DoYouLinux
I just forgot a thing to ask. In my layout, I have to "Gnd" connections for ground and two "Vdd" connections for a supply voltage. Actually, each of them will be independently connected to each pad, and then will be tied together to the supply and to the ground plane outside the chip (on a PCB). However, in my schematic, I have only one "Vdd" pin and one "Gnd" pin.
When I ran LVS, do I need to set any parameter (in Assura LVS) ?
Will the LVS report some error message ?
Thank you very much in advance,
DYLinux
