AnalogDE
Anybody have any suggestions for the following non-convergence errors? It only appears to be happening at certain corners at 100C. Node X is a high-impedence node (floating). I am running eldo and have tried playing around with the TUNING setting. Seems to work at STANDARD accuracy but I need higher accuracy. Any suggestions appreciated.
Newton: No convergence at time :0.259943Nano ; try to pass over... pb on or around node X TIME 2.609432e-10: end of non-convergence points Newton: No convergence at time :0.263943Nano ; try to pass over... pb on or around node Y TIME 2.649432e-10: end of non-convergence points Newton: No convergence at time :0.269943Nano ; try to pass over... pb on or around node X
