Verilog-AMS
Analysis
Modeling
Design
Theory
Welcome, Guest. Please
Login
or
Register.
Please follow the Forum
guidelines
Sep 27
th
, 2024, 2:25am
Home
Help
Search
Login
Register
PM to admin
Simulators
Circuit Simulators
› Hspice capacitance calculation error
Previous topic
Next topic
Hspice capacitance calculation error (Read 2312 times)
Analog_Designer
Egypt
Nov 01
st
, 2012, 1:03am
Hello!
I'm working with the 65nm technology. While i was characterizing the technology by calculating the extrinsic capacitance i got the following probelm:
In the operating point output file the values for cgtot differs from that calculated at the same bias while doing the sweep on vgs.
It's, not only, the cgtot that differs but also all the capacitance values are different in the operating point file than that i get from the vgs sweep.
Any suggestions?
Thanks in advance.........
Ibrahim
figures.rar
IP Logged
raja.cedt
Re: Hspice capacitance calculation error
Reply #1 -
Nov 1
st
, 2012, 3:05am
what do you mean by same bias, while doing .op, you will set some current and Vgs, but while sweeping vgs you can't maintain same current and if you maintain same current Vgs should change.
Raj.
IP Logged
Analog_Designer
Egypt
Reply #2 -
Nov 1
st
, 2012, 3:35am
The same bias means the same vgs and vds by letting the cursor refer to the same vgs and the vds is constant
IP Logged
Previous topic
Next topic
Forum Jump »
» 10 most recent Posts
» 10 most recent Topics
Design
- RF Design
- Analog Design
- Mixed-Signal Design
- High-Speed I/O Design
- High-Power Design
- Mixed-Technology Design
Analog Verification
Measurements
- RF Measurements
- Other Measurements
Modeling
- Semiconductor Devices
- Passive Devices
- Behavioral Models
Design Languages
- Verilog-AMS
- VHDL-AMS
Simulators
»» Circuit Simulators
- RF Simulators
- AMS Simulators
- Timing Simulators
- System Simulators
- Logic Simulators
Other CAD Tools
- Entry Tools
- Unmet Needs in Analog CAD
General
- Tech Talk
- News
- Comments and Suggestions
- Opportunities
« Home
‹ Board
» Powered by
YaBB 2.2.2
YaBB
Copyright 2002-2024
Designer’s Guide
All rights reserved.
Send comments or questions to
editor@designers-guide.org
. Consider
submitting
a paper or model.
