Aug 30th, 2024, 7:18pm
question on pole zero analysis (Read 4659 times)
microe
Oct 12th, 2014, 10:22pm
Hi there,
I am trying to use pole zero analysis to find out the amplifier's open loop poles and zeros, but not sure how to set it up.
I used to use stb to check the stability of amplifier with load and feedback connected. It can gives me some idea of the pole and zeros from Bode plot, but not the exact location as pole/zero effect on mag/phase are mixed together. It is hard to identify unless they are far from each other.
That is the reason for me to try pole zero analysis. However, if I keep the feedback connected, what pole zero analysis tells me is the close loop pole/zero. What I am really interested in is open loop pole/zero.
If I break the loop to do pole/zero analysis, then the loading will be different (I understand picking a good breaking point will help to some degree).
I wonder if there is a way to set up pole/zero analysis to give me the open loop pole/zero but not have to break the loop, similar to stb analysis.
Your help is appreciated!
raja.cedt
Re: question on pole zero analysis
Reply #1 - Oct 13th, 2014, 1:54am
Do you PZ analysis, it will give you so many pole even for a single stage opamp and search for dominate poles but still you have to think about which pole corresponds to which node.
Otherwise open the loop with large inductor(take care of the loading by adding caps on both sides of the ind) and find res and cap at each by injecting some ac current.
Raj.
microe
Reply #2 - Oct 13th, 2014, 6:17pm
Hi Raj,
Thanks.
Is there a way to get the pole/zero without breaking the loop? Similar to stb can give us the loop mag/phase without breaking the loop
Thanks.
buddypoor
Bremen, Germany
Reply #3 - Nov 7th, 2014, 1:20am
microe wrote on Oct 13th, 2014, 6:17pm:
Hi Raj,
Thanks.
Thanks.
Microe - if you are interested in open-loop poles/zeros why do you want to analyze the circuit under closed-loop conditions?
This I cannot understand.
microe
Reply #4 - Nov 7th, 2014, 6:39pm
Thanks for the reply.
It is the same reason as we connect amplifier in feedback when we do stb analysis: 1) we want it DC biased correctly 2) we want include the feedback loading
buddypoor
Bremen, Germany
Reply #5 - Nov 8th, 2014, 2:28am
microe wrote on Nov 7th, 2014, 6:39pm:
OK - that`s what I have expected. However, for analyzing under open-loop conditioins you must open the loop (ac wise!) - otherwise, you have no open-loop conditions. On the other hand - I know what you means: You want to restore the dc operational point as well as the load properties.
To achive this, there are several methods - depending on the particular conditions.
For example, if you can neglect load changes (opamp output) the simplest method is to place an ac test source BETWEEN the low-resistive output and the feedback path.
As another simple method, you can use a very large inductor for ac opening the loop - and inject the test sighnal using a very large capacitor.
For a 100% correct method you must use the method as described by Middlebrook (open-loop analysis with double injection).
As far as I know, the STB analysis also makes use of Middlebrooks method.
