https://designers-guide.org/forum/YaBB.pl Design >> RF Design >> Design of a Hartley Oscillator https://designers-guide.org/forum/YaBB.pl?num=1162464409 Message started by tripod2000 on Nov 2nd, 2006, 2:46am |
Title: Design of a Hartley Oscillator Post by tripod2000 on Nov 2nd, 2006, 2:46am Hey all, http://www.electronics-tutorials.com/oscillators/oscillator-basics.htm shows a Hartley oscillator and a Colpitts circuit. There is a formula for finding a frequency of a Colpitts oscillator, but not a Hartley oscillator. I believe I need a Hartley oscillator for my design with a frequency of about 100kHz or about 1MHz. Could someone please suggest a formula to work out what values of componants I would need. (I will have a variable capacitance.) Thank You ;) |
Title: Re: Design of a Hartley Oscillator Post by loose-electron on Nov 2nd, 2006, 7:52am That web site uses small signal schematics with a large signal transistor in the middle of it. Also, the Hartley Colpitts oscillators don't get used a heck of a lot anymore. They tend to exist in one transistor designs from prior to 1965 or so. Care to tell us a bit more about what you are trying to do and perhaps we can be of help? thanks Jerry |
Title: Re: Design of a Hartley Oscillator Post by tripod2000 on Nov 2nd, 2006, 9:07am I'm working on a control system like a Theremin. I want the oscillator frequency to change with a changing capacitance caused by a hand moving near an aerial. I figured on the Hartley because of the changing capacitance, the simplicity (cost being a factor in the design) and the feedback ration being constant seemed like a good idea. Thank You. |
