https://designers-guide.org/forum/YaBB.pl Design >> RF Design >> Why is the drain current bidirectional?? https://designers-guide.org/forum/YaBB.pl?num=1176126402 Message started by zhangjerome on Apr 9th, 2007, 6:46am |
Title: Why is the drain current bidirectional?? Post by zhangjerome on Apr 9th, 2007, 6:46am I am now designing a VCO with cross-coupled PMOS. After tran simulation, I found out that the drain current is bidrectional with positive maximum about 2mA and negative maximum about -4mA. I think the drain current of PMOS should always be nagative since drain voltage is always lower than source voltage. And in a VCO the drain current of a PMOS should be switched on and off with a value between 0 and some nagative value. So why does this happen?? Does anybody encounter this problem before?? Best regrads. Thank you. Jerome |
Title: Re: Why is the drain current bidirectional?? Post by vivkr on Apr 10th, 2007, 2:40am Hi Jerome, Is your drain voltage by any chance exceeding the source or bulk voltages? Regards Vivek |
Title: Re: Why is the drain current bidirectional?? Post by zhangjerome on Apr 10th, 2007, 4:27am Vivkr: The bulk and the sourcr are both conneted to Vdd and theie voltage are always higher than drain voltage. |
Title: Re: Why is the drain current bidirectional?? Post by vivkr on Apr 10th, 2007, 7:17am Hi Jerome, THat is really strange. Would you mind posting your VCO schematic? Regards Vivek |
Title: Re: Why is the drain current bidirectional?? Post by zhangjerome on Apr 11th, 2007, 1:17am The attatched file is the current waveform of each PMOS node and the drain voltage waveform. The gate voltage has similar waveform as the drain voltage except 180 degree phase difference since this PMOS is cross-coupled with another PMOS. |
Title: Re: Why is the drain current bidirectional?? Post by zhangjerome on Apr 11th, 2007, 1:23am And the schematic of the VCO. The ideal current source is just used for simplity and in the real circuit it is in fact a current mirror. |
Title: Re: Why is the drain current bidirectional?? Post by vivkr on Apr 11th, 2007, 1:45am Dear Jerome, I see that the cross-couple PMOS have source-bulk shorted and this goes to the current mirror. So the bulk of these devices is not really hard tied to VDD, neither is the source. Forgive me for harping on the same theme but have you checked the transient voltages at the drain, soruce and bulk. One way to get rid of the issue would be to tie the bulk of the cross-coupled PMOS to vdd directly. However, the ultimate question is - What is the impact of the bidirectional drain current on your circuit? Regards Vivek |
Title: Re: Why is the drain current bidirectional?? Post by zhangjerome on Apr 13th, 2007, 11:54pm On the top it is not a current source but in fact a Vsource. The current source is at the bottom. I just think this phenominon is unusual so maybe there are some mistakes with my circuit or the model files. Thank you. |
Title: Re: Why is the drain current bidirectional?? Post by yang on May 7th, 2007, 2:46pm In my opinion, it is due to the parasitic components, specifically parasitic capacitors inside PMOS. If the frequency is high enough, the source current is not the inner source current of a transistor that you want. You can check it by reduce the oscillation frequency. I suggest you investigate the model firstly. |
