https://designers-guide.org/forum/YaBB.pl Design >> RF Design >> Nonlinearity of RF front-end https://designers-guide.org/forum/YaBB.pl?num=1180769396 Message started by chielite on Jun 2nd, 2007, 12:29am |
Title: Nonlinearity of RF front-end Post by chielite on Jun 2nd, 2007, 12:29am Hello, everyone, Help needed Q: The nonlinearity of a RF front-end can be modeled as a 7-order polynomial expression: vo=k1*vi+k3*vi^3+k5*vi^5+k7*vi^7+.... For GSM1800, it has 374 channels with the channel width of 200kHz. (1)Please find a theoretical expression for the 1-dB compression point, intercept point, and SFDR. (2)Use GSM1800 as an example, please calculate the 1-dB compression point, intercept point, and SFDR for every channel. (3)Please comment your results for GSM1800. (4)If k1=33.996; k3=-5743.7; k5=-4.0016*1.e6; k7=-8.0760*1.e8 , please use the expressions you obtained above to plot some meaningful graph for each expression. Also, please propose your own solutions to reduce the effects. |
Title: Re: Nonlinearity of RF front-end Post by loose-electron on Jun 5th, 2007, 11:15am This sounds like a university homework assignment. Suggest you go back to the material presented in class and see whats there. If all else fails, talk to the professor. |
