https://designers-guide.org/forum/YaBB.pl Design >> Mixed-Signal Design >> What signal in cables, analog or digital? https://designers-guide.org/forum/YaBB.pl?num=1185289754 Message started by reset on Jul 24th, 2007, 8:09am |
Title: What signal in cables, analog or digital? Post by reset on Jul 24th, 2007, 8:09am Hi, I'm designing a transmitter with MIMO capability. I hope to use a separate analog module for RF (maybe also IF), and a digital module for baseband processing. But I'm not sure where to put DACs/ADCs. Digital interface seems to be more reliable, but requires more cables. However, I don't want to put several DACs/ADCs on a single board as they could occupy large areas. Could you pls give me some advice on this? Thank you! |
Title: Re: What signal in cables, analog or digital? Post by mg777 on Jul 24th, 2007, 9:39am http://www.cpri.info/ |
