https://designers-guide.org/forum/YaBB.pl Design >> RF Design >> how to measure front end linearity https://designers-guide.org/forum/YaBB.pl?num=1185787190 Message started by James Bond on Jul 30th, 2007, 2:19am |
Title: how to measure front end linearity Post by James Bond on Jul 30th, 2007, 2:19am Hi, all Can anybody here tell me how to test RF front end linearity in SpectreRF? I know how to test lna linearity and mixer linearity. But when they come together, how to set the pss simulation ? Can anybody share the manual? Thank you very much. Best Regards james |
Title: Re: how to measure front end linearity Post by mindy on Aug 1st, 2007, 9:31am Just use the same method as you use in mixer linearity simulation. I guess you are talking about IP3 testing. You can use tran or pss for IP3. :) |
