https://designers-guide.org/forum/YaBB.pl Design >> Analog Design >> feedback problem in fully differential op https://designers-guide.org/forum/YaBB.pl?num=1192225041 Message started by James Bond on Oct 12th, 2007, 2:37pm |
Title: feedback problem in fully differential op Post by James Bond on Oct 12th, 2007, 2:37pm Hi, all Recently I met a problem, I have designed a two stage fully differential opamp with cmfb, supply is 1.2V. The open loop simulation is ok, 40db gain. The input voltage bias voltage is 0.6V, cm reference is 0.6v as well. However, when I add four 40k resistors between out+ and input- , out- and input+ to create a unity gain, I found that the dc voltage at the gate of the input pair transistors are 0.8V, and the output dc level is 1.18V. Did anybody have this problem before ? How did you solve this problem? Any suggestions would be appreciated. Best Regards James |
Title: Re: feedback problem in fully differential op Post by MonteCarlo on Oct 13th, 2007, 3:21am How about posting the circuit diagram to help us help you? |
Title: Re: feedback problem in fully differential op Post by tosei on Oct 14th, 2007, 8:50pm Hi, May be loading effect due to the 40K resistor? You might no have enough current driving capability in your output stage? Regards tosei |
