https://designers-guide.org/forum/YaBB.pl Design >> Analog Design >> Different simulation result for gm and d(Id)/d(vg) https://designers-guide.org/forum/YaBB.pl?num=1193191358 Message started by Julian18 on Oct 23rd, 2007, 7:02pm |
Title: Different simulation result for gm and d(Id)/d(vg) Post by Julian18 on Oct 23rd, 2007, 7:02pm use cadence to simulate a single CS MOS, plot gm vs. vg and d(Id)/d(vg) vs. vg, get different results (similar but different plots) , why? Thanks |
Title: Re: Different simulation result for gm and d(Id)/d Post by Julian18 on Oct 23rd, 2007, 8:20pm here is my simulation result |
Title: Re: Different simulation result for gm and d(Id)/d Post by rajeee1000 on Oct 23rd, 2007, 9:12pm The difference is probably due to the error in the computation of the derivative. Finite difference tends to the actual derivative as the sweep step approaches zero. May be, you will see the curves closer and closer as you progressively decrease the VGS sweep step. Rajesh |
Title: Re: Different simulation result for gm and d(Id)/d Post by Julian18 on Oct 23rd, 2007, 11:20pm rajeee1000 wrote on Oct 23rd, 2007, 9:12pm:
Thanks Rajesh I use very small increment to simulate this but I still get the result as before. difference still be there. below is the simulation result |
Title: Re: Different simulation result for gm and d(Id)/d Post by buddypoor on Oct 24th, 2007, 12:26am Hello Julian, since I am not familiar with Cadence: where is the source of "gm" ? Does Cadence have an output parameter called "gm" ? In Addition, gm is the "mutual conductance" and comprises more than purely the slope of the Id-vg-curve (e.g. the influence of the backward conductance). May be this is the difference. Regards Lutz (Germany) |
Title: Re: Different simulation result for gm and d(Id)/d Post by Julian18 on Oct 24th, 2007, 2:50am buddypoor wrote on Oct 24th, 2007, 12:26am:
Hi Lutz: In cadence you can get gm of a MOS using save statement, spectre will give a variable to you called /M0/gm, and you can use it to plot. As to the mutual conductance, Is the definition of gm d(Id)/d(Vg)?? what else does it have to include to become mutual conductance? Thanks |
Title: Re: Different simulation result for gm and d(Id)/d Post by buddypoor on Oct 24th, 2007, 4:25am Hi, Julian ! In fact, there are three small-signal parameters for the transconductance g: 1.) The mutual transconductance measures the amount of drain current increase caused by the increment in the gate bias: 2.) The drain transconductance measures the amount of drain current increase caused by the increment in the drain bias. 3.) Finally, the bulk transconductance consideres the effect of back-gate bias on the drain current Perhaps, the g values corresponding to 2) resp. 3) are not included in the g-calculation of the simulator. In this context it is, of course, important whether you are simulating the pure MOSFET or the MOSFET with a load resistance. Moreover, there may be a difference between an "intrinsic" transconductance and the transconductance measured between the terminals of the DUT (influence of internal resistances). Finally, here is a good reference fpr MOS-modelling: iwailab.ep.titech.ac.jp/pdf/mnakagawa/mnakagawa_mthesis.pdf Regards Lutz[size=12][/size] |
Title: Re: Different simulation result for gm and d(Id)/d Post by Ken Kundert on Oct 24th, 2007, 9:41am Is there any source degeneration? That would be included in dId/dVg but not in gm. -Ken |
Title: Re: Different simulation result for gm and d(Id)/d Post by genuineintel on Oct 24th, 2007, 8:38pm The error might come from the AC part of Gm model, I guess. :-/ |
Title: Re: Different simulation result for gm and d(Id)/d Post by toseii on Oct 25th, 2007, 7:01pm Hi, When computing the d(Id)/d(vg) you are also considering the effect of the output impedance of the device, while when computing the gm you get the actual value of the controlled output current source "with the output shorted" (no effect of finite output impedance) in the two port model. tosei |
Title: Re: Different simulation result for gm and d(Id)/d Post by RobG on Oct 25th, 2007, 7:59pm I noticed the same thing a few weeks ago... I've been designing analog for 15 years so I don't think ;) I was doing something dumb. I did a parametric sweep of a current source into a diode connected device. The slope dI/dVgs did not match gm. It might have been the Rs and Rd terms - I never thought to pursue that. There might be affects from Vds if that is changing too. It will be a while before I can get back to it... Be aware some companies, including one that begins with N, have a sub-circuit for their mosfets that includes more than just a mosfet. This could make gm different than dI/dVgs rg |
Title: Re: Different simulation result for gm and d(Id)/d Post by nxing on Nov 13th, 2007, 5:26pm I think the difference is coming from the "big" gm and "small" gm. means for big gm, you get the gm at every DC point, for small gm, you get actually the derivative at that point. they are not necessary the same. |
Title: Re: Different simulation result for gm and d(Id)/d Post by jimwest on Nov 15th, 2007, 6:56pm Hi Julian, It's the difference between the gm(just the parameter of the mos) and the effective gm (the ability of converting the voltage to the current). There are guys who will affect the drain current such as vds. When plotting gm at the OP, the effect of vds will not be involved. But when plotting the dI/dv, everything which will affect the drain current is introduced. Kinda Regards, Jim |
