https://designers-guide.org/forum/YaBB.pl Design >> High-Speed I/O Design >> PCB trace model https://designers-guide.org/forum/YaBB.pl?num=1228896460 Message started by jeffyan on Dec 10th, 2008, 12:07am |
Title: PCB trace model Post by jeffyan on Dec 10th, 2008, 12:07am hi all, how can i do PCB trance modelling, can you provide some good information? thanks jeff :) |
Title: Re: PCB trace model Post by SRF Tech on Dec 10th, 2008, 11:51am Hi Jeff, There are a whole slew of tools out there than can help you. A lot depends on what level of accuracy you need. If you are dealing with an very precision, narrow or broadband RF signal, you may need to get a 3-D field solver. Ansoft, is one example of many big names that have a variety of tools that can help out. (google spicelink or HFSS for an introduction) If your design is lower frequency and Transmission line accuracy is not as critical (only you can decide this), you could probably get away with a simple strip-line/micro-strip calculator and so forth. here is a simple example website: http://www.technick.net/public/code/cp_dpage.php?aiocp_dp=util_pcb_imp_calculator though there are many others. A lot depends on the accuracy you need and how much time and money you are able to invest. |
Title: Re: PCB trace model Post by Frank Wiedmann on Dec 11th, 2008, 12:50am If you would like to use a field solver, you could take a look at the free Sonnet Lite, see http://www.sonnetsoftware.com/products/lite/index.asp. |
Title: Re: PCB trace model Post by jeffyan on Dec 11th, 2008, 4:41am thank you so much!! |
Title: Re: PCB trace model Post by kanan on Jul 10th, 2009, 8:08pm For not so accurate applications you could try using lmg in the cadence environment to visualize the pcb cross-section and export it to mtline. |
Title: Re: PCB trace model Post by raja.cedt on Jul 10th, 2009, 9:08pm hi why don't you use transmission line model? |
