https://designers-guide.org/forum/YaBB.pl Design >> Analog Design >> closed-loop class-d design https://designers-guide.org/forum/YaBB.pl?num=1311694526 Message started by tomers on Jul 26th, 2011, 8:35am |
Title: closed-loop class-d design Post by tomers on Jul 26th, 2011, 8:35am Hello all, I'm trying to design an analog loop for a Class-D audio amplifier output stage to increase PSRR. My input is already a digital PWM stream and i want to implement an analog-integration-of-digital-signals type of loop, which I've seen in several articles, one is given in the circuit attached (classd-1.jpg). It consists of 2 integrators and a comparator. both the input and output are digital PWM streams at ~400KHz. I've played around with it for a while and I'm having hard time to figure out what time constants should i set for the integrators for this concept to work properly. If i set the F3dB of the first integrator too low - it integrates over the audio band, outputting a saw-tooth-like waveform averaged around the audio itself. After a few cycles the average increases to a point where the output clips, losing the switching of the circuit. On the other hand, if the first integrator knee frequency is higher than the audio band - i get something similar to the square wave at the input, and the second integrator is now averaging over the audio band, this time THIS one clips after a few cycles. I think i'm missing something here and i'd appreciate your thoughts. Thanks Tomer |
