https://designers-guide.org/forum/YaBB.pl Design >> Analog Design >> 3.3V vs 14V https://designers-guide.org/forum/YaBB.pl?num=1353449147 Message started by grosser on Nov 20th, 2012, 2:05pm |
Title: 3.3V vs 14V Post by grosser on Nov 20th, 2012, 2:05pm hello will it be safe to use 3.3V transistors with 4.2V supply ? Gate oxide breakdown, diode junction breakdown is 7V and punch through voltage is 6.6V. It is 0.35um process Or I should use hv transistors ready for 14V? regards grosser |
Title: Re: 3.3V vs 14V Post by boe on Nov 20th, 2012, 2:55pm Grosser, this is determined by the reliability of the transistor wrt. hot-electron injection. It does not depend on breakdown or punch-through voltage. You need reliability data from your fab to answer that; the issue will be most critical for minimum-length transistors - B O E |
Title: Re: 3.3V vs 14V Post by analog_wiz on Nov 20th, 2012, 7:05pm Hi Grosser, it would depend on the topology you are using.What you can do it run a transient simulation and measure the voltage across the transistor junctions(eldo has something called reliability simulations...). You could also use ultrasim and it has reliability checks for checking voltages across various junctions and it can flag violations if any when a transient sim is run. |
Title: Re: 3.3V vs 14V Post by carlgrace on Nov 21st, 2012, 9:21am The voltage requirements are based on differences between terminals (except for things like well breakdown). If you don't ever have the 4.2 V across a gate-source or drain-source junction you're golden. Be sure you carefully check the startup sequence and ESD structures on your chip though... you may need a custom pad (depends on your pad library of course) |
Title: Re: 3.3V vs 14V Post by Lex on Nov 22nd, 2012, 7:57am carlgrace wrote on Nov 21st, 2012, 9:21am:
I would think that VGS and VGD should not exceed 3.3V, and expect that VDS can handle higher voltages. |
