Design >> RF Design >> how to define psin for class AB and class E PAs?
https://designers-guide.org/forum/YaBB.pl?num=1075831037
Message started by sealion on Feb 3rd, 2004, 9:57am
Title: how to define psin for class AB and class E PAs?
Post by sealion on Feb 3rd, 2004, 9:57am
pls help me how to define the psin of input and output ports when simulate class AB and class E PAs by using spectreRF, i'm a new user, thanks for your reply.
Title: Re: how to define psin for class AB and class E PA
Post by Andrew Beckett on Feb 5th, 2004, 2:44pm
Your question is a little vague - but one thing I would
recommend is to use the "port" component rather
than "psin" - it's a more direct map to spectre's port
component, and it is considerably easier to use.
Without knowing what you're trying to measure, nobody
will be able to advise you how to set it up...
Regards,
Andrew.
Post by sealion on Feb 15th, 2004, 12:07pm
You are right, I'm a new user, can you tell me how to define them?
Thanks a lot!
Sealion
Post by Andrew Beckett on Mar 4th, 2004, 9:14am
Well, your reply was also vague, so no I can't tell you
how to define them. I still don't know what you're trying to measure.
Andrew (without his ESP headgear on)
