https://designers-guide.org/forum/YaBB.pl Measurements >> RF Measurements >> ---- FR4 PCB Substrate parameters ---- https://designers-guide.org/forum/YaBB.pl?num=1112361912 Message started by Alez on Apr 1st, 2005, 5:25am |
Title: ---- FR4 PCB Substrate parameters ---- Post by Alez on Apr 1st, 2005, 5:25am Dear all, I am trying to simulate my PCB with FR4 substarte but I could not find the parameters of this substarte. Does anyone have this information ? Best regards, Alez |
Title: Re: ---- FR4 PCB Substrate parameters ---- Post by Paul on Apr 1st, 2005, 6:15am Alez, this is not an easy task, as each FR4 supplier has its own manufacturing "receipt". The best way to get acceptable results is to get the parameters from your PCB supplier. The parameters depend on the exact materials used. Also take care on gold plating and so which may modify your line thickness. You can also have a look at the following message board: http://www.edaboard.com Paul |
Title: Re: ---- FR4 PCB Substrate parameters ---- Post by Alez on Apr 1st, 2005, 8:35am Thanks a lot Paul :) |
Title: Re: ---- FR4 PCB Substrate parameters ---- Post by larry flowers on Sep 18th, 2012, 10:18am FR4 is not a good choice of PCB substrate for circuits that operates at above 1 GHz. larry |
Title: Re: ---- FR4 PCB Substrate parameters ---- Post by raja.cedt on Nov 17th, 2012, 6:39am Better use Arlon. Thanks, raj. |
