https://designers-guide.org/forum/YaBB.pl Simulators >> Circuit Simulators >> How to evaluate resistance for simulation of differential circuit???? https://designers-guide.org/forum/YaBB.pl?num=1231747377 Message started by Yutao Liu on Jan 12th, 2009, 12:02am |
Title: How to evaluate resistance for simulation of differential circuit???? Post by Yutao Liu on Jan 12th, 2009, 12:02am Dear all, I simulate a differential amplifier with balanced/unbalanced convertors as mentioned in "a Test Bench for Differential Circuit". But I don't quite understand how to determine the value of the Rid, Ric, Rod and Roc. |
Title: Re: How to evaluate resistance for simulation of differential circuit???? Post by pancho_hideboo on Jan 12th, 2009, 7:15am Yutao Liu wrote on Jan 12th, 2009, 12:02am:
Set these values as termination or load conditions you like. No one except for you knows termination or load conditions you like. |
