https://designers-guide.org/forum/YaBB.pl Modeling >> Passive Devices >> virtuoso passive component designer https://designers-guide.org/forum/YaBB.pl?num=1234900114 Message started by oermens on Feb 17th, 2009, 11:48am |
Title: virtuoso passive component designer Post by oermens on Feb 17th, 2009, 11:48am i am having some problems with VPCD: 1. I set up my environment according to users guide, but when I try to do custom inductor/transformer i get this message: WARNING: cannot find display.drf file [/opt/cadence/test.tlib/display.drf]. You need to copy your [display.drf] file to directory [/home/.vpcm_datdir] manually. ERROR: starting GTE failed. however i have the .techfile and display.drf in the correct folders... my process's procfile was encrypted so i exported it to "internal format" using vpcm so i could modify it. 2. I can't generate cells with ground+shield, i get the following message: ("error" 56 t nil ("*Error* No contact!"))\w *WARNING* Pcell evaluation for vpcm/PCM_shld_rect/layout has the following error(s): \w *WARNING* ("error" 56 t nil ("*Error* No contact!")) \w *WARNING* Error kept in "errorDesc" property of the label "pcellEvalFailed" on layer/purpose "marker/error" in the submaster. \w \o ("error" 56 t nil ("*Error* No contact!")) any ideas how to solve either of these problems? |
Title: Re: virtuoso passive component designer Post by Andrew Beckett on Feb 17th, 2009, 7:54pm For the first one, support for custom inductors using GTE has been dropped - the flow wasn't completed, and the approach of supporting existing pcells was preferred. Overall you should contact Cadence customer support - VPCD is now in limited support mode, so best to discuss your needs via your usual Cadence support channel. Best Regards, Andrew. |
