https://designers-guide.org/forum/YaBB.pl Simulators >> RF Simulators >> input referred noise in timedomain pnoise sim https://designers-guide.org/forum/YaBB.pl?num=1249840210 Message started by gk on Aug 9th, 2009, 10:50am |
Title: input referred noise in timedomain pnoise sim Post by gk on Aug 9th, 2009, 10:50am Hi, I am trying to simulate noise a Switched Capacitor Integrator based on http://www.designers-guide.org/Analysis/sc-filters.pdf . For including sampled aliased noise, I use noise_type as time domain. At the end of the sim, I can see the output referred noise, but the simulator refuses to plot the input referred noise. Is there any way to either plot the input referred noise or any other way of calculating my SNR. There is a similar post, but here wa no answer given for this. http://www.designers-guide.org/Forum/YaBB.pl?num=1186710158 Thanks, gk |
Title: Re: input referred noise in timedomain pnoise sim Post by Forum Administrator on Aug 10th, 2009, 9:59am Use a voltage source or current source as the input source. Do not use a port. -Ken |
Title: Re: input referred noise in timedomain pnoise sim Post by gk on Aug 10th, 2009, 10:10am Hi Ken, Thanks for your reply. I am already using a voltage source as input. Also, I simulated a simple R-switch and C to find the integrated noise and it gives me the right (and same) value for different R's, but as soon as I put a transistor, I get different values of integrated noise/PSD for different transistor widths. Isnt it just supposed to be kT/C and independent of R?? Thanks, gk |
Title: Re: input referred noise in timedomain pnoise sim Post by analog_ali on Oct 2nd, 2009, 6:26pm Hi, In order to get the thermal noise power independent of "R", maximum number of sidebands (msb) in the sim. setup has to be changed together with "R". (As R decreases, msb should increase to take care of the aliasing.) But did you eventually have any success in simulating the input-referred noise of the integrator? I have tried to do the same simulation, but have not been able to confirm the 2kT/C result for a single-ended integrator. I have tried both of the closed loop configurations discussed in the delta-sigma paper by Ken Kundert (Figures 10 & 11). None of the approaches lead to 2kT/C. I could only obtain this result when I reset the integrator every cycle (i.e. when the integrator effectively becomes a SC gain stage) Any ideas why this is the case?? Thanks, Ali |
