https://designers-guide.org/forum/YaBB.pl Simulators >> System Simulators >> eps in simulink relay block https://designers-guide.org/forum/YaBB.pl?num=1251758635 Message started by ycm on Aug 31st, 2009, 3:43pm |
Title: eps in simulink relay block Post by ycm on Aug 31st, 2009, 3:43pm HI, I want to use a relay in my simulink model and confused by the switch on point, the default value is 'eps' and the switch off point , default is '-eps', what is eps here? is it a number or something else? thanks. |
