https://designers-guide.org/forum/YaBB.pl Modeling >> Passive Devices >> Attributes depending on the value of voltages and currents https://designers-guide.org/forum/YaBB.pl?num=1255608174 Message started by Emmanuele on Oct 15th, 2009, 5:02am |
Title: Attributes depending on the value of voltages and currents Post by Emmanuele on Oct 15th, 2009, 5:02am HI to everybody. I'm using Design Entry HDL (in Cadence SPB 16.01), an upgraded version of PSpice. I would like to know if it's possible to define the value of an attribute (say, the resistance of a resistor) depending on the istantaneous value of a voltage or a current in the circuit. I know that it's possible to define values which depend on constants, or fixed parameters; but I'd like to define comething more complex. For instance, I'd like to define a resistor with a resistance depending on a function of the integral of the power dissipated in its (ie R*I^2). Any suggestions? Thanks a lot, Emmanuele |
Title: Re: Attributes depending on the value of voltages and currents Post by Geoffrey_Coram on Oct 20th, 2009, 5:17am I'd write the model in Verilog-A. If you're stuck in PSpice without Verilog-A, I expect you could write a subckt with dependent sources that measure the I and V of the resistor, make a current that's equal to I*V, and dump that onto a capacitor; the instantaneous voltage on the cap is then the integral of the dissipated power. (You'll need a resistor to ground for the dc solution, but you can make it very large if you're not modeling the heat transfer away from the device.) |
