Design >> High-Speed I/O Design >> What are the blocks of USB IO transmitter in general?
https://designers-guide.org/forum/YaBB.pl?num=1256740874
Message started by somisetty on Oct 28th, 2009, 7:41am
Title: What are the blocks of USB IO transmitter in general?
Post by somisetty on Oct 28th, 2009, 7:41am
Hi all,
Title: Re: What are the blocks of USB IO transmitter in general?
Post by raja.cedt on Oct 28th, 2009, 9:44pm
hi,
   it depends on the architecture but commonly you can see driver,pre driver, serializer
Thanks,
rajasekhar.
Post by somisetty on Nov 1st, 2009, 8:41pm
Thanks rajasekhar...
Post by rrv on Apr 30th, 2010, 2:51am
Hi Can you explain little more secifically , for an example
FS block diagram , what type of Driver and Reciever does it require
and related stuff
Thanx
