https://designers-guide.org/forum/YaBB.pl Measurements >> RF Measurements >> Measurement wideband differential signal path https://designers-guide.org/forum/YaBB.pl?num=1268473836 Message started by Visjnoe on Mar 13th, 2010, 1:50am |
Title: Measurement wideband differential signal path Post by Visjnoe on Mar 13th, 2010, 1:50am Dear all, I'm thinking about the test interface of a wideband (~500MHz) IQ differential signal path. What do you consider the best approach to test this, both from the on-chip as off-chip perspective? I was considering the use of (tapered) source followers to drive the signal off chip (probably will have to drive a few pF's) and than to measure it using an active probe. Another option would be to feed it (also using source followers) into an off-chip voltage buffer/amplifier. Unfortunately, it's apparently hard to find components that provide a high input impedance + the required bandwidth. Furthermore, most datasheets don't mention input capacitance. Specifically, on the on-chip test buffers (~source followers) do you see any specific disadvantage/advantage of using DC coupling or AC coupling? Regards |
