https://designers-guide.org/forum/YaBB.pl Measurements >> RF Measurements >> Phase noise measurement from equipment is USB or DSB? https://designers-guide.org/forum/YaBB.pl?num=1274422891 Message started by casual on May 20th, 2010, 11:21pm |
Title: Phase noise measurement from equipment is USB or DSB? Post by casual on May 20th, 2010, 11:21pm The default/typical plot from cadence is the USB noise (upper side band), which is 3dB lower than double side band (DSB) phase noise. typical plot -->(direct plot ->pnoise analysis->function: phase noise) May I know the measure we get from RF equipments is USB or LSB or DSB?? I am new to RF stuff. |
Title: Re: Phase noise measurement from equipment is USB or DSB? Post by pancho_hideboo on May 21st, 2010, 3:04am supermoment wrote on May 20th, 2010, 11:21pm:
Measurement by special equipment is PM noise. See the followings. http://www.designers-guide.org/Forum/YaBB.pl?num=1050465395/22#22 http://www.designers-guide.org/Forum/YaBB.pl?num=1256925601/4#4 |
Title: Re: Phase noise measurement from equipment is USB or DSB? Post by casual on May 21st, 2010, 3:44am a bit confuse after reading the thread. Per my understanding 1. Phase noise is a combination of PM noise and AM noise. PM noise dominates in close in region (low freq in dBc) while AM noise usually dominates high-freq noise. 2. PM noise can be more than 0dBc in low freq 3. the typical phase noise we got from cadence is USB. (which is already consists of both AM & PM noise, whichever is the worst) 4. spectrum analyzer can measure "output phase noise". However cannot measure PM noise correctly near to low freq. Thus see flat region. 5. Special equipment can do the task (measuring close in noise correctly or PM noise) Hopefully it is correct :p |
Title: Re: Phase noise measurement from equipment is USB or DSB? Post by pancho_hideboo on May 21st, 2010, 3:48am supermoment wrote on May 21st, 2010, 3:44am:
Simple measurement by Spectrum Analyzer is no more than C/N0. See http://www.designers-guide.org/Forum/YaBB.pl?num=1241917016 supermoment wrote on May 21st, 2010, 3:44am:
Title: Re: Phase noise measurement from equipment is USB or DSB? Post by casual on May 21st, 2010, 3:59am I used the wrong word.. correction here: 4. spectrum analyzer can measure "Voltage phase noise" or Sv. However cannot measure PM noise correctly near to low freq. Thus see flat region. Voltage phase noise = Sv Phase noise =Sphi (I shall call it: truly phase noise) refering to http://www.designers-guide.org/Analysis/rf-sim.pdf (pg12) |
Title: Re: Phase noise measurement from equipment is USB or DSB? Post by pancho_hideboo on May 21st, 2010, 4:01am supermoment wrote on May 21st, 2010, 3:59am:
It is no more than "Voltage Noise". It is not "Voltage Phase Noise". Correctly we call it "Sideband Voltage Noise" or "Normalized Sideband Voltage Noise". Here we don't include any "Phase" term in it. |
Title: Re: Phase noise measurement from equipment is USB or DSB? Post by casual on May 21st, 2010, 4:21am ok wrong again it is called sideband voltage noise=Sv which consist of both amplitude and phase noise components. |
Title: Re: Phase noise measurement from equipment is USB or DSB? Post by pancho_hideboo on May 21st, 2010, 4:35am supermoment wrote on May 21st, 2010, 4:21am:
See http://www.designers-guide.org/Forum/YaBB.pl?num=1050465395/14#14 |
Title: Re: Phase noise measurement from equipment is USB or DSB? Post by Mayank on Jun 29th, 2010, 9:09pm Also, Quote:
On the other hand, Lphi (which is a small signal approximation of phase noise b/w osc. linewidth & Fosc/2 ) can go above 0 dBc below corner freq. But true Sphi wont. As per my understanding, none of the simulators can solve true Sphi correctly for very low frequencies. What i still wonder is if it's due to lack of proper gaussian flicker noise model in technology models OR is it due to simulator's inability to solve gaussian noise in low-freq. as opposed to Lorentzian after linewidth. |
Title: Re: Phase noise measurement from equipment is USB or DSB? Post by pancho_hideboo on Jul 18th, 2010, 3:22am Mayank wrote on Jun 29th, 2010, 9:09pm:
I don't know what you mean by Lphi. But in actual Measurement using Actual Instruments, LSSB(f)=C/N0 never go above 0dBc/Hz but SΦ(f) can go above 0dBrad/Hz. On the other hand, in simulation using current EDA Tool, LSSB(f) could go above 0dBc/Hz at low offset especially in the presence of 1/f noise. Mayank wrote on Jun 29th, 2010, 9:09pm:
It is simply due to a limitation of small signal analysis. See http://www.designers-guide.org/Forum/YaBB.pl?num=1263835149/6#6 |
