https://designers-guide.org/forum/YaBB.pl Measurements >> RF Measurements >> LNA gain and input matching https://designers-guide.org/forum/YaBB.pl?num=1281853392 Message started by yixiusky on Aug 14th, 2010, 11:23pm |
Title: LNA gain and input matching Post by yixiusky on Aug 14th, 2010, 11:23pm Hello everyone I would like to ask one question I designed one LNA works frome 1.8 to 2.2 GHz. After meausrement, the input and output matching are ok, but the gain shiift to 1.5GHz. I could not think the reason. Could you help me? Thank you very much. |
Title: Re: LNA gain and input matching Post by pancho_hideboo on Aug 15th, 2010, 3:40am yixiusky wrote on Aug 14th, 2010, 11:23pm:
Do you want to mean "a peak of gain or S21" ? Show me frequency characteristics of S11, S22 and S21 as LNA. yixiusky wrote on Aug 14th, 2010, 11:23pm:
Show me frequency characteristics of S11, S22 and S21 of intrinsic device. |
Title: Re: LNA gain and input matching Post by vp1953 on Aug 15th, 2010, 10:44am That seems like a large shift (assuming you are referring to peak gain). How was the measurement done - was the LNA output buffered? If not, what was the load on the LNA output for the gain measurement? |
Title: Re: LNA gain and input matching Post by yixiusky on Aug 30th, 2010, 12:12am Thank you very much for reply, I did more measurement, and i attach the result here. (1) input matching S11 (both magnitude and smith chart) (2) Output matching S22 (both magnitude and smith chart) (3) Gain and NF My LNA design is 1.8GHz to 2.2GHz, the peak gain should appear at 2 GHz. However, the inputmaching peak is around 2GHz, but the output peak is at around 1.5GHz. Then the peak Gain is also 1.5GHz. and the gain decrese around 5dB compare with post layer simulation result. I do not know the reason why the Peak Gain is shifted to 1.5GHz, and also decreased around 5dB. Could you please help me? thank you so much |
Title: Re: LNA gain and input matching Post by yixiusky on Aug 30th, 2010, 12:18am I also attach the gain and NF response here. We can see the peak gain is at 1.6GHz, not 2GHz. My target gain is 15dB, now is 11.9dB. |
Title: Re: LNA gain and input matching Post by pancho_hideboo on Aug 30th, 2010, 6:52am yixiusky wrote on Aug 30th, 2010, 12:12am:
Title: Re: LNA gain and input matching Post by yixiusky on Aug 30th, 2010, 7:58pm I use resistive feedback type LNA , I attach the schematic here |
Title: Re: LNA gain and input matching Post by pancho_hideboo on Aug 31st, 2010, 6:08am yixiusky wrote on Aug 30th, 2010, 7:58pm:
Title: Re: LNA gain and input matching Post by RFICDUDE on Sep 1st, 2010, 2:49am Your circuit has two resonant circuits that are coupled. The resistive feedback couples the tuned output load and the resonant input matching network, so it is very difficult to simultaneously match the input and have the output tuned for maximum output at the same frequency. It is even more difficult if you are trying to maintain a controlled (matched) impedance at the output too. Some systems can tolerate some amount of gain variation over frequency, so having the gain at a maximum may not be as important as maintaining a good match and low noise figure. Alternatively, you could decouple the output and input by removing the shunt feedback, but then the input matching network would have to be redesigned for the impedance change and the gain would be higher (presumably) from input to output. But the increased input/output isolation would decoupled the two tuned networks such that they will not interact (unless there are significant parasitic coupling paths). |
Title: Re: LNA gain and input matching Post by vp1953 on Sep 2nd, 2010, 4:08pm Hi RFICDUDE, Why in your opinion, did not the measurement data correlate with simulation results? Assuming that there are no bugs with the PDK and the simulations were done correctly, the difference between simulations and actual results seem quite large. |
Title: Re: LNA gain and input matching Post by yixiusky on Oct 2nd, 2010, 1:24am when i measure this LNA, i found one problem. In this LNA, the inductor is connected to VDD. So when i meausre the chip, the VDD Pad is easily die. And then the DC condition is totally wrong. What should i do to protect the vdd pad? |
Title: Re: LNA gain and input matching Post by yixiusky on Oct 2nd, 2010, 8:39pm when i measure this LNA, i found one problem. In this LNA, there are two VDD pad. One is connect to bias circuit, while another one is connected to LNA core (inductor), as shown in schematic. When i meausre the chip, among all pads, only the VDD Pad (connected to inductor) is easily dead. And then there is no DC flow from this VDD pad. What should i do to protect the vdd pad? |
Title: Re: LNA gain and input matching Post by yixiusky on Oct 2nd, 2010, 10:19pm pancho_hideboo wrote on Oct 2nd, 2010, 9:50pm:
Thank you very much. All pad are ESD PAD Actually, there is RC filter between Vdd and gate of M2. i did not draw in the shematic here. So i think the gate of M2 has no problem. |
Title: Re: LNA gain and input matching Post by yixiusky on Oct 2nd, 2010, 10:36pm Thank you very much if the ESD diode is broken, what should I do? Yes, i set the current limit for Vdd regulator. |
Title: Re: LNA gain and input matching Post by yixiusky on Oct 2nd, 2010, 10:56pm thank you very much i will try it right now |
Title: Re: LNA gain and input matching Post by yixiusky on Oct 2nd, 2010, 11:59pm pancho_hideboo wrote on Oct 2nd, 2010, 10:46pm:
I have question You mean place all 10pF, 100pF, 1000pF and 100kohm in parralel? or place just one by one, and test? My frequency is wideband, from 1.8~2.7Ghz. From VDD to ground, when I place the capacitor, which value should I choose? |
Title: Re: LNA gain and input matching Post by pancho_hideboo on Oct 3rd, 2010, 2:13am yixiusky wrote on Oct 2nd, 2010, 11:59pm:
10pF must be placed in most near of Vdd. 100pF is next. And 1000pF is next to 100pF. 100kohm is near of 1000pF. BTW, what value do you apply as stimulus power in Network Analyzer ? |
Title: Re: LNA gain and input matching Post by snaildr on May 7th, 2011, 7:52pm Why do you use resistive feedback and also inductive degeneration? I though the point of using resistive feedback and thus making the NF a bit worse is to go without any inductor and save a ton of area, right? |
