Design >> High-Speed I/O Design >> Difference between SERDES, SGMII, 1000BASE-X ?
https://designers-guide.org/forum/YaBB.pl?num=1285248321
Message started by gavin on Sep 23rd, 2010, 6:25am
Title: Difference between SERDES, SGMII, 1000BASE-X ?
Post by gavin on Sep 23rd, 2010, 6:25am
Hello:
Can someone help clarify the difference between SERDES, SGMII & 1000BASE-X?
Thanks,
Gavin
Title: Re: Difference between SERDES, SGMII, 1000BASE-X ?
Post by loose-electron on Sep 24th, 2010, 3:00pm
"SERDES" (Serializer Deserializer) is a global statement of a circuit function. - Generally means take parallel data, convert to serial data, send it over a transmission medium (ofter wires, but not always) and receive it and process back to parallel data.
Many devices (some of what you mention) use SerDes structures, USB1,2,3, Ethernet, Firewire (and many others) have SerDes structures within them. However, they differ in data rates, encoding, compensation methods, etc, etc.
