https://designers-guide.org/forum/YaBB.pl Modeling >> Passive Devices >> Variable number of components https://designers-guide.org/forum/YaBB.pl?num=1312355699 Message started by transconductance on Aug 3rd, 2011, 12:14am |
Title: Variable number of components Post by transconductance on Aug 3rd, 2011, 12:14am Hello, i am new to this forum. I hope this is the right section to put my question in. I would like to make a model with a variable number of components.(passives like resistors or diodes) The number should be programmable by the component menu. The components should be connected in series. Is there an easy way to do this? Thanks a lot tr |
Title: Re: Variable number of components Post by DDC on Feb 3rd, 2012, 12:44am If you only do static analysis you can use switches. |
Title: Re: Variable number of components Post by boe on Feb 3rd, 2012, 7:26am Transconductance, tool? language? If Verilog-A is OK for you, see e.g. this thread: http://www.designers-guide.org/Forum/YaBB.pl?num=1328123432 - B O E |
