https://designers-guide.org/forum/YaBB.pl Measurements >> RF Measurements >> Group Delay measurement in Cadence https://designers-guide.org/forum/YaBB.pl?num=1313280431 Message started by Larry_80 on Aug 13th, 2011, 5:07pm |
Title: Group Delay measurement in Cadence Post by Larry_80 on Aug 13th, 2011, 5:07pm Could someone please put me through how to plot/measure the average group delay vs frequency of a TransImpedance Amplifier in Cadence. Is it possible to plot -d(phase)/dw, if i recall, that's the definition of group delay! If i haved to find the derivative of the phase to do this, how do i plot phase in cadence? Thanks |
Title: Re: Group Delay measurement in Cadence Post by rfcooltools.com on Sep 7th, 2011, 5:29pm Larry_80, Depending on the version of cadence you are using it should be an explicit function in the calculator called "groupDelay". http://rfcooltools.com |
Title: Re: Group Delay measurement in Cadence Post by rfidea on Sep 21st, 2011, 12:01pm Or you can use the deriv() function if you like, deriv(phase(VF("/vout"))/2/pi |
