https://designers-guide.org/forum/YaBB.pl Other CAD Tools >> Physical Verification, Extraction and Analysis >> layout to schematic problem https://designers-guide.org/forum/YaBB.pl?num=1317106580 Message started by lanfird on Sep 26th, 2011, 11:56pm |
Title: layout to schematic problem Post by lanfird on Sep 26th, 2011, 11:56pm If I want to use parasitic capacitors of layout instead of mimcap offered by the process, how should I pass LVS? The problem is that when I extract layout capacitor to schematic capacitor (which is a capacitor not provided by the process), I could't get LVS passed. |
Title: Re: layout to schematic problem Post by ywguo on Sep 30th, 2011, 7:30am What do you mean by parasitic caps? What is the structure? Generally I think you need SPICE model, and LVS model for it. It is better that there is a pcell. -- Yawei |
