https://designers-guide.org/forum/YaBB.pl Measurements >> RF Measurements >> What sets the phase-noise spec in RF transmitters? https://designers-guide.org/forum/YaBB.pl?num=1321608235 Message started by weber8722 on Nov 18th, 2011, 1:23am |
Title: What sets the phase-noise spec in RF transmitters? Post by weber8722 on Nov 18th, 2011, 1:23am Hi, I am more familiar with receivers, and there phase-noise is extremely important for blocker performance. However, why phase-noise is important for typical RF mobile station transmitters? What it is impacting most? For standards like GSM, WLAN, EDGE, etc. :-? Bye Stephan |
Title: Re: What sets the phase-noise spec in RF transmitters? Post by raja.cedt on Nov 18th, 2011, 2:55am hello, In transmitters local oscillator noise is amplified by the subsequent amplifier stages and is eventually fed to the antenna together with the wanted signal. The wanted signal is therefore surrounded by a band of noise originating from the phase noise of the local oscillator Thanks, raj. |
Title: Re: What sets the phase-noise spec in RF transmitters? Post by loose-electron on Nov 21st, 2011, 2:25pm Out of band spectral spreading? Essentially keeping the transmitter in its channel would be my guess here. |
Title: Re: What sets the phase-noise spec in RF transmitters? Post by RFICDUDE on Nov 25th, 2011, 5:04pm Probably EVM. |
Title: Re: What sets the phase-noise spec in RF transmitters? Post by rfcooltools.com on Jan 10th, 2012, 10:02pm weber8722, All answers so far are correct, For mobile devices the transmit being at max is correlated with receiver seeing min power ie rx is near the thermal noise floor . In a full duplex (transmit and receive operating simultaneously) TX phase noise out of band directly increases the noise at the receiver input minus filtering if any. For low lower order modulation bpsk qpsk phase noise is less of a concern in band for tx. But for higher order modulation such as QAM then the system budget for in band phase noise is stricter since the constellation can be degraded (ie EVM) at the time of transmit. In wire line communications the transmit can degrade other receivers on the same line. http://rfcooltools.com |
