https://designers-guide.org/forum/YaBB.pl Simulators >> Timing Simulators >> UltrasimVerilog error: failed to parse the netlist https://designers-guide.org/forum/YaBB.pl?num=1326438060 Message started by ahhfyz on Jan 12th, 2012, 11:00pm |
Title: UltrasimVerilog error: failed to parse the netlist Post by ahhfyz on Jan 12th, 2012, 11:00pm Hi, everyone! I have a system including verilog (modules and sub-modules) and schematic. It can be simulated in SpectreVerilog, but failed in UltrasimVerilog: "Error found by UltraSim. ERROR (USIM-18610): The UltraSim simulator failed to parse the netlist. Correct the above errors and run the simulation again." What should I do next? Thank you! |
Title: Re: UltrasimVerilog error: failed to parse the netlist Post by AMS_ei on Aug 2nd, 2016, 4:49am Hi, Please use the following two lines and check if it works. -sysv_ext +.v -simcompatible_ams spectre Thank you. |
