https://designers-guide.org/forum/YaBB.pl Design Languages >> VHDL-AMS >> VHDL code for booth multiplier https://designers-guide.org/forum/YaBB.pl?num=1340808267 Message started by kalos on Jun 27th, 2012, 6:44am |
Title: VHDL code for booth multiplier Post by kalos on Jun 27th, 2012, 6:44am Hello, I should realize the VHDL description of a digital multiplier that realize Booth's algorithm (encoded in 2 bits) for two terms represented on N and M bits, respectively, and with a result of N + M bits. I have attached the 2 files: 1)booth that should implement the booth's algorithm 2)test that should simulate Are they correct to implement and simulate a booth's multiplier? I wrote and simulated with ALDEC ACTIVE-HDL Student Edition. Compile the code and i have 0 Errors, but in the simulation the result of multiplication is "UUUU" and the WAVEFORM panel is empty. �so I thought that the codes are wrong. please help me. 1) library IEEE; use IEEE.STD_LOGIC_1164.ALL; use IEEE.STD_LOGIC_ARITH.ALL; use IEEE.STD_LOGIC_UNSIGNED.ALL; entity booths is � GENERIC(k : POSITIVE := 7); --input number word length less one � Port ( a,b : in STD_LOGIC_VECTOR (k downto 0); � � � � �mul : out STD_LOGIC_VECTOR (2*k+1 downto 0)); end booths; architecture Behavioral of booths is begin � process(a,b) variable m: std_logic_vector (2*k+1 downto 0); variable s: std_logic; begin m:="00000000"&b; s:='0'; for i in 0 to k loop if(m(0)='0' and s='1') then � m(k downto k-3):= m(k downto k-3)+a; � s:=m(0); � m(k-1 downto 0):=m(k downto 1); elsif(m(0)='1' and s='0') then � � �m(k downto k-3):= m(k downto k-3)-a; � � �s:=m(0); � � �m(k-1 downto 0):=m(k downto 1); else � � �s:=m(0); � � �m(k-1 downto 0):=m(k downto 1); end if; end loop; � � �mul<=m; end process; end Behavioral; 2) library IEEE; use IEEE.STD_LOGIC_1164.ALL; use IEEE.STD_LOGIC_ARITH.ALL; use IEEE.STD_LOGIC_UNSIGNED.ALL; entity Testbench_di_Booth is end Testbench_di_Booth; architecture behavior of Testbench_di_Booth is component booths GENERIC(k : POSITIVE := 7); --input number word length less one Port( a,b : in STD_LOGIC_VECTOR (k downto 0); � � � mul : out STD_LOGIC_VECTOR (2*k+1 downto 0)); end component; --Inputs signal A : STD_LOGIC_VECTOR (7 downto 0):= "00000011"; signal B : STD_LOGIC_VECTOR (7 downto 0):= "00000100"; --Outputs signal MUL : STD_LOGIC_VECTOR(15 downto 0); begin --Instantiate the UnitUnder Test (UUT) uut: booths PORT MAP (a => A, �b => B, �mul => MUL); � �--Stimulus process stim_proc: process begin --insert stimulus here A<="00000011"; B<="00000100"; wait for 500 fs; A<="00000110"; B<="00000111"; wait for 500 fs; A<="00001011"; B<="00000100"; wait for 500 fs; wait; end process; end; |
