https://designers-guide.org/forum/YaBB.pl Modeling >> Transmission Lines and Other Distributed Devices >> mtline spectre connection https://designers-guide.org/forum/YaBB.pl?num=1371058996 Message started by hpvlsi on Jun 12th, 2013, 10:43am |
Title: mtline spectre connection Post by hpvlsi on Jun 12th, 2013, 10:43am When using mtline model in cadence spectre schematic simulation, why I can not connect output of one mtline to output of another mtline? (warnings show there will be short circuit and floating nodes) |
Title: Re: mtline spectre connection Post by sheldon on Jul 8th, 2013, 6:37am hpvlsi, You are getting a warning because you are shorting two outputs. Tested the case of two mtlines outputs shorted and the simulation seems to run. Does your circuit simulate? Sheldon |
Title: Re: mtline spectre connection Post by Frank Wiedmann on Jul 8th, 2013, 6:58am This question has been answered at http://www.cadence.com/community/forums/T/26497.aspx. |
Title: Re: mtline spectre connection Post by hpvlsi on Jul 20th, 2013, 11:36am Hi, the simulation result is fine, I just do not like the warnings, and http://www.cadence.com/community/forums/T/26497.aspx solves it. Thanks. sheldon wrote on Jul 8th, 2013, 6:37am:
Title: Re: mtline spectre connection Post by hpvlsi on Jul 20th, 2013, 11:36am Thanks! That is exactly what I need Frank Wiedmann wrote on Jul 8th, 2013, 6:58am:
