https://designers-guide.org/forum/YaBB.pl Analog Verification >> Analog Functional Verification >> Ultrasim syntax for probing current at particular nodes https://designers-guide.org/forum/YaBB.pl?num=1411044916 Message started by ranjang on Sep 18th, 2014, 5:55am |
Title: Ultrasim syntax for probing current at particular nodes Post by ranjang on Sep 18th, 2014, 5:55am Hi, My requirement is to probe current at particular nodes for verification purpose.I am using ultrasim simulator and running simulation with irun -amsf option I am writing like this in acf.scs file where I give complete path for the port where I want current. .probe i(top_tb.u_k0_wrapper.u_pr1.u_ana_core.u_k1.u_k2.u_k3.u_k4.ildo1.IBIAS) I don't see the current probing and it gives some warning Cannot find element 'IBIAS' because it is missing or it was cut in circuit 'subckt_name' during the simulation. |
Title: Re: Ultrasim syntax for probing current at particular nodes Post by AMS_ei on Jan 18th, 2017, 8:17am Hi, Please see below: 1. Create a probe.tcl file. In that file, you have to use "-flow" option as shown below: probe -create -flow -shm -ports top_tb.u_k0_wrapper.u_pr1.u_ana_core.u_k1.u_k2.u_k3.u_k4.ildo1.IBIAS 2. Parse the file in the irun option with -input option Hope this helps. Thank you. |
