https://designers-guide.org/forum/YaBB.pl Simulators >> Circuit Simulators >> Effective length of capacitance in less than or equal to zero (Cadence Spectre) https://designers-guide.org/forum/YaBB.pl?num=1477728027 Message started by Estimulo on Oct 29th, 2016, 1:00am |
Title: Effective length of capacitance in less than or equal to zero (Cadence Spectre) Post by Estimulo on Oct 29th, 2016, 1:00am Hello Everyone, While simulating a design of 3:8 decoder, spectre is producing an error as : Error found by spectre during initial setup. ERROR (CMI-2215): I0.I6.I0.M1: The effective length of capacitance is less than or equal to zero. I have tried changing width of M1 and transistors present in instances I0 and I6. Please tell me, how can it be resolved. Thanks |
Title: Re: Effective length of capacitance in less than or equal to zero (Cadence Spectre) Post by Geoffrey_Coram on Oct 31st, 2016, 10:47am I think there's something wrong with your setup. You shouldn't be getting those warnings about "'nf' is not a valid parameter" I wonder if you're using a netlist from one PDK with a model library from another PDK. |
Title: Re: Effective length of capacitance in less than or equal to zero (Cadence Spectre) Post by Abhi_iitm on Jun 2nd, 2018, 5:27am Hey i am facing the exact same issue with the same library , could someone please help? |
Title: Re: Effective length of capacitance in less than or equal to zero (Cadence Spectre) Post by Abhi_iitm on Jun 2nd, 2018, 5:28am Geoffrey_Coram wrote on Oct 31st, 2016, 10:47am:
I am facing the same issue though i am using the pdk for the same library kindly help, Regards |
Title: Re: Effective length of capacitance in less than or equal to zero (Cadence Spectre) Post by Andrew Beckett on Jun 2nd, 2018, 6:45am It would help somewhat if you said which PDK (and models) you were using - info such as the foundry, process node, and ideally any version number for the PDK or model files. That will significantly increase the chance of somebody being able to help you. Regards, Andrew. |
Title: Re: Effective length of capacitance in less than or equal to zero (Cadence Spectre) Post by Abhi_iitm on Jun 2nd, 2018, 6:57am it is UMC_18_CMOS These are the directory details indicating exact model: G-9FD-MIXED_MODE_RFCMOS18-1.8V_3.3V-1P6M-MMC_ \ UM180FDKMFC00000OA-FDK-Ver.A02_PB \ /UM180FDKMFC00000OA_A02_DESIGNKIT \ /UM180FDKMFC00000OA_A02_PB/UMC_18_CMOS |
Title: Re: Effective length of capacitance in less than or equal to zero (Cadence Spectre) Post by Geoffrey_Coram on Jun 4th, 2018, 7:11am Is "n_18_mm" a mismatch model? If you look in the model files, can you determine if it is a subckt or model card? If you use regular (not mismatch) models, does the simulation work? (You probably should not post the actual model files, since this is UMC's IP and it would likely violate an NDA.) |
