https://designers-guide.org/forum/YaBB.pl Simulators >> AMS Simulators >> Netlist generation from config view https://designers-guide.org/forum/YaBB.pl?num=1497531730 Message started by Gp on Jun 15th, 2017, 6:02am |
Title: Netlist generation from config view Post by Gp on Jun 15th, 2017, 6:02am Hi All, I am using the cadence virtuoso tool. I created the config view from the schematic. For Verilog-AMS netlist generate, I use the following command line: runams -lib lib_name -cell cell_name -view config -netlist -rundir top_dir Now my question is, How to generate the .amsbind.scs file with netlist?which contain connect module (amscf.scs) . Is there a missing option in command line? Thanks. |
Title: Re: Netlist generation from config view Post by Andrew Beckett on Jul 25th, 2017, 9:17am runams will do this provided that the netlist assembly succeeded - it's in the rundir/netlist. To generate an analog control file, you'd have to pass -state so that it has an ADE state to specify the analysis set up and so on. Otherwise you can write your own and pass -analogcontrol to the runams command line. Andrew. |
