https://designers-guide.org/forum/YaBB.pl Simulators >> Circuit Simulators >> Analog signal conditioning circuit design https://designers-guide.org/forum/YaBB.pl?num=1506204179 Message started by v2h on Sep 23rd, 2017, 3:02pm |
Title: Analog signal conditioning circuit design Post by v2h on Sep 23rd, 2017, 3:02pm Hello everyone, I want to design an analog signal conditioning circuit for an application. I have a photo multiplier tube and its light output is converted to an analog signal using a voltage divider. The application is to digitize the analog signal. Could you anyone please suggest a good source where I can start to implement this design? Thank you. |
