Simulators >> AMS Simulators >> how to override the parameter of verilog-a module with array parameter
https://designers-guide.org/forum/YaBB.pl?num=1513852500
Message started by davidshw on Dec 21st, 2017, 2:35am
Title: how to override the parameter of verilog-a module with array parameter
Post by davidshw on Dec 21st, 2017, 2:35am
if a verilog-a module has an array parameter, such as
moduel test (A,B)
parameter integer p1[1:4]='{1,2,3,4} ;
analog begin
end
endmoudle
when instantiating this module in hspice or spectre, how to override the array parameter?
xdut  a b test  p1=???
Title: Re: how to override the parameter of verilog-a module with array parameter
Post by Andrew Beckett on Dec 21st, 2017, 7:26am
Assuming you've corrected the spelling mistakes in the VerilogA module, in spectre syntax (for spectre as the simulator) it would be:
xdut (a b) test p1=[5 6 7 8]
Regards,
Andrew.
