https://designers-guide.org/forum/YaBB.pl Measurements >> Other Measurements >> Measuring transfer characteristics of fully differential OTA https://designers-guide.org/forum/YaBB.pl?num=1521806904 Message started by indra0804 on Mar 23rd, 2018, 5:08am |
Title: Measuring transfer characteristics of fully differential OTA Post by indra0804 on Mar 23rd, 2018, 5:08am Hi experts, Can you pls suggest a good reference to know about the procedure to measure the open loop gain and phase response of a two stage fully differential OTA using signal source and CRO? Thanks, Indrajit |
Title: Re: Measuring transfer characteristics of fully differential OTA Post by Ken Kundert on Mar 23rd, 2018, 11:37am Middlebrook developed those measurements to a high art. He used a signal generator driving a current probe to excite the circuit, and he used a vector volt meter rather than an oscilloscope to measure magnitude and phase. You might be able to automate his measurements with a network analyzer. I suggest you start by looking at his publications on loop gain. -Ken |
