Modeling >> Behavioral Models >> Verilo A model
https://designers-guide.org/forum/YaBB.pl?num=1530621118
Message started by ouijdane on Jul 3rd, 2018, 5:31am
Title: Verilo A model
Post by ouijdane on Jul 3rd, 2018, 5:31am
Hello,
I want to write a verilog A code of a space state average model of a dc dc boost converter.
Can anyone tell me the first step and howa should I proceed?
Thank you in advance.
Title: Re: Verilo A model
Post by Geoffrey_Coram on Jul 5th, 2018, 12:24pm
I don't know what a "state space average model" is.
What do you want as your inputs and outputs of this model? Can you write equations for currents and voltages, or is a state-space models at a higher level? (in which case, Verilog-A might not be the right language)
Post by Frank Wiedmann on Jul 6th, 2018, 9:00am
If you want to learn about state space average models of dc/dc converters, the books by Christophe Basso (http://cbasso.pagesperso-orange.fr/Spice.htm) are probably a good starting point. If you want to learn Verilog-A, you can start right on this site at http://www.designers-guide.org/VerilogAMS/
