https://designers-guide.org/forum/YaBB.pl Design Languages >> Verilog-AMS >> ideal switch convergence problem https://designers-guide.org/forum/YaBB.pl?num=1532025418 Message started by liletian on Jul 19th, 2018, 11:36am |
Title: ideal switch convergence problem Post by liletian on Jul 19th, 2018, 11:36am I have cadence convergence issue. I am using an verilog A relay `include "constants.vams" `include "disciplines.vams" module relay (p, n, ps, ns); parameter real thresh=0; // threshold (V) output p, n; input ps, ns; electrical p, n, ps, ns; analog begin @(cross( V(ps,ns) - thresh, 0 )) ; if (V(ps,ns) > thresh) V(p,n) <+ 0; else I(p,n) <+ 0; end endmodule Then the schematic is as following, but it has convergence issue. Can you please help to see if cadence can have a look on the problem? The square in the schematic is the relay. the clock waveform is as following: It keeps reporting the congergence error as below: |
Title: Re: ideal switch convergence problem Post by liletian on Jul 19th, 2018, 11:37am error message |
Title: Re: ideal switch convergence problem Post by liletian on Jul 19th, 2018, 11:37am waveform |
Title: Re: ideal switch convergence problem Post by Ken Kundert on Jul 19th, 2018, 8:50pm If the switches are open, the capacitor floats. |
Title: Re: ideal switch convergence problem Post by liletian on Jul 19th, 2018, 9:12pm how to solve it? thanks |
Title: Re: ideal switch convergence problem Post by Ken Kundert on Jul 19th, 2018, 10:18pm resistors to ground. |
