https://designers-guide.org/forum/YaBB.pl Simulators >> Circuit Simulators >> Vertical Bathtub Curve in Cadence ViVA https://designers-guide.org/forum/YaBB.pl?num=1533639037 Message started by cheap_salary on Aug 7th, 2018, 3:50am |
Title: Vertical Bathtub Curve in Cadence ViVA Post by cheap_salary on Aug 7th, 2018, 3:50am We can plot Timing Bathtub Curve, that is, Horizontal Bathtub Curve from Eye Diagram in recent Cadence ViVA. Here eyeBERLeftApprox() and eyeBERRightApprox() are available for this purpose. However we also have to plot Amplitude Bathtub Curve, that is, Vertical Bathtub Curve. And we need BER Contour Plot. How can I plot Vertical Bathtub Curve and BER Contour Plot in Cadence ViVA ? Attached figure is a result of Keysight ADS. Actual Instruments also support Both Horizontal and Vertical Bathtub Curves, BER Contour Plot. |
Title: Re: Vertical Bathtub Curve in Cadence ViVA Post by Andrew Beckett on Aug 7th, 2018, 6:16am Not currently. It's a good suggestion though - could you please contact Cadence Customer Support so that we can plan this enhancement with R&D? Regards, Andrew. |
