https://designers-guide.org/forum/YaBB.pl Simulators >> RF Simulators >> I have a question https://designers-guide.org/forum/YaBB.pl?num=1538415452 Message started by nguyen on Oct 1st, 2018, 10:37am |
Title: I have a question Post by nguyen on Oct 1st, 2018, 10:37am :(I have a question about spetre pnoise simulation, is the output a double sided thanks |
Title: Re: I have a question Post by Andrew Beckett on Oct 21st, 2018, 4:59am It depends! I'd suggest using Spectre from MMSIM15.1 onwards (note, after this, the release was renamed SPECTRE - so you could also use SPECTRE 16.1, 17.1 or 18.1) together with IC617 (or now IC618), and then you can use the new "timeaverage" noise type on the pnoise form. Then when you plot on the direct plot form, you can a) be sure you're getting phase noise (rather than output noise in dBc) and b) specify whether you want single or double sideband phase noise. That was one of the reasons Cadence had a revamp of the pnoise/hbnoise setup in these releases, to remove the ambiguity there had been previously and avoid users having to ask these questions... Regards, Andrew. |
