https://designers-guide.org/forum/YaBB.pl Design >> Analog Design >> MDAC for Pipeline ADC - Timing Analysis - Part 2 https://designers-guide.org/forum/YaBB.pl?num=1543453220 Message started by repah on Nov 28th, 2018, 5:00pm |
Title: MDAC for Pipeline ADC - Timing Analysis - Part 2 Post by repah on Nov 28th, 2018, 5:00pm Hello, I am examing this MDAC for a Pipeline ADC and am confused about the style of the notation on the schematic in terms of the switches. What do they mean ? The switches say VDD/GND and P2D and P1D. Does that mean set that point to VDD at P2D and GND at P1D ? How would I do this ? Thank you. |
Title: Re: MDAC for Pipeline ADC - Timing Analysis - Part 2 Post by DanielLam on Nov 29th, 2018, 12:52pm If I had to guess, I'm guessing P1d means the switch has Vdd on it (which probably means on). P2d means the switch has Gnd on it (which probably means off). |
Title: Re: MDAC for Pipeline ADC - Timing Analysis - Part 2 Post by polyam on Dec 8th, 2018, 4:28pm VDD and GND are the supply and ground of the switches. If it is a simple transmission gate it means that the bulks are connected to VDD and GND for PMOS and NMOS respectively. The MDAC essentially works with two non-overlapping clocks and their delayed version. P1 and P2 are the non-overlapping clocks. P1D is the delayed version of P1. P2D is the delayed version of P2. Hope it's a good guess! |
