https://designers-guide.org/forum/YaBB.pl Simulators >> Circuit Simulators >> SAR ADC Cadence to Matlab https://designers-guide.org/forum/YaBB.pl?num=1543519852 Message started by repah on Nov 29th, 2018, 11:30am |
Title: SAR ADC Cadence to Matlab Post by repah on Nov 29th, 2018, 11:30am Hello, I am designing a SAR ADC in Cadence Virtuoso/Spectre and want to export the output of the DAC to MATLAB. Is there a way to automate this in Cadence Virtuoso - a file write block in Verilog-A ? Is this publicly available, included in Virtuoso or available somewhere else ? Any tutorials about this available ? Thank you. |
Title: Re: SAR ADC Cadence to Matlab Post by DanielLam on Nov 29th, 2018, 12:29pm I suggest looking into Matlab Spectre Toolbox. You can directly pull the Cadence output data from Matlab with the cds_srr command. The support website has examples, although it is a little hard to read. In the end, it requires a bit of trial and error to get the syntax right. Otherwise, you can write outputs with an ocean script. I used to do this until I learned about the Matlab Spectre Toolbox. |
