https://designers-guide.org/forum/YaBB.pl Design >> Analog Design >> Inverter PSRR. https://designers-guide.org/forum/YaBB.pl?num=1560761486 Message started by Jacki on Jun 17th, 2019, 1:51am |
Title: Inverter PSRR. Post by Jacki on Jun 17th, 2019, 1:51am Hello, One confusion of the PSRR in the normal inverter-base amplifier. From my calculation it should be -6dB, but I see a lot of people use +6dB. From the definition of the PSRR, it is the gain from VDD to Vout divided by the signal voltage gain, if so I think the PSRR of the inverter should be -6dB. Any comments or calculation on +6dB PSRR? Thank you. |
Title: Re: Inverter PSRR. Post by Jacki on Jun 17th, 2019, 11:19pm this issue is clear now, i think it depends on how do we define the PSRR in the expression. |
