https://designers-guide.org/forum/YaBB.pl Simulators >> RF Simulators >> How to generate QAM modulation signal in Cadence Spectre https://designers-guide.org/forum/YaBB.pl?num=1569857385 Message started by thebatmanisback on Sep 30th, 2019, 8:29am |
Title: How to generate QAM modulation signal in Cadence Spectre Post by thebatmanisback on Sep 30th, 2019, 8:29am Hi, I have a Polar (EER) Power Amplifier designed in Cadence Virtuoso. I need to generate the QAM signals to analyse EVM, ACPR, etc. Since it is polar modulated (EER), I need to generate the amplitude and phase signals. I searched on the internet and found that I could generate I,Q signals in MATLAB and then import the files in Cadence spectre as pwl files. I have seen a lot of research papers doing analysis with polar modulated power amplifiers. Is there a standard method to generate these signals and perform analysis? I am new to this topic. Sorry, if the question is naive. Thank you! :) |
