Other CAD Tools >> Physical Verification, Extraction and Analysis >> Cap extraction of an IC  PAD
https://designers-guide.org/forum/YaBB.pl?num=1654702617
Message started by vlsi_design on Jun 8th, 2022, 7:36am
Title: Cap extraction of an IC  PAD
Post by vlsi_design on Jun 8th, 2022, 7:36am
Hi, I want to extract the capacitance of an IC PAD. Unfortunately there are no pins and I cannot pass lvs and do extraction. I may use a metal res to  get a pin out and extract but are there better ways to do this?
Title: Re: Cap extraction of an IC �PAD
Post by Maks on Jun 21st, 2022, 6:12am
Yes - do LVS and extraction using layout only, without doing cross-referencing to schematic - and you can get your parasitics for your design (do not create shorts or opens, or other wrong things - in which case, the results will be meaningless).
