Simulators >> Circuit Simulators >> Importing Models Into LTSPICE
https://designers-guide.org/forum/YaBB.pl?num=1665869087
Message started by MooCow27 on Oct 15th, 2022, 2:24pm
Title: Importing Models Into LTSPICE
Post by MooCow27 on Oct 15th, 2022, 2:24pm
I am modeling a transistor in IC-CAP using the spice level 3 simulator. I extracted these parameters and tried importing them as a spice model in LT spice, but the output current is less than half and the curves look different. What am I missing? Thanks
Title: Re: Importing Models Into LTSPICE
Post by Frank Wiedmann on Oct 17th, 2022, 4:32am
https://groups.io/g/LTspice/ might be a better place for asking this question.
Post by mhx on Oct 20th, 2022, 1:08am
The value for Is should be 164.2e-12. Your curves looks like LEVEL=1 was used, not 3.
