Design >> Analog Design >> Two stage opamp differential feedback with different i/p and o/p common mode
https://designers-guide.org/forum/YaBB.pl?num=1668008345
Message started by vlsi_design on Nov 9th, 2022, 7:39am
Title: Two stage opamp differential feedback with different i/p and o/p common mode
Post by vlsi_design on Nov 9th, 2022, 7:39am
Hi, I am designing a two stage differential amplifier with different i/p common mode voltage and o/p common mode voltage. When I connect it in closed loop using resistors R2 and R1 , dc current will flow due to difference in common mode. Is it ok for dc current to flow when the amplifier will be used in closed loop ? I want to characterise the closed loop response like step response etc.. Thanks
